[phpBB Debug] PHP Warning: in file [ROOT]/includes/functions_content.php on line 677: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions_content.php on line 677: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions_content.php on line 677: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions_content.php on line 677: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions_content.php on line 677: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions_content.php on line 677: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions_content.php on line 677: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions_content.php on line 677: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions_content.php on line 677: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions_content.php on line 677: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions_content.php on line 677: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions_content.php on line 677: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead עזרה בקבלת החלטה(החלטה התקבלה) | VAGIT
שלום לכולם נפלה החלטה להחליף את הואגית שלי אני נקרע בין שתי רכבים ספורטיביים אך שונים בצורה מוחלטת מצד אחד תמיד חשבתי וידעתי שהרכב הבא יהיה גולף gti חדשה עד לליפני יומים שנהגתי בהונדה טייפ R זו היתה חוויה מטורפת מכונת נהיגה קיצונית וכזאת היא קיצונית קשה חדה ולא הייתי מגדיר אותה כרכב יום יומי ובכל זאת משהו עמוק בפנים קרה באיזור הלב ועכשיו אני קרוע בין שניהן מה אתם אומרים ללכת על רגוע סולידי על גבול האנונימיות לעיני הציבור ואם זאת מהנה או על משהו שהוא רחוק מיזה צעקני קשה קיצוני מהנה בטרוף אני יודע שרובכם כאן היתם בוחרים בגולף ובכל זאת דעתכם הישרה והאמיתית אולי תנתב אותי לכיוון הנכון תודה
נערך לאחרונה על ידי lavie333 בתאריך 26 יוני 2017, 15:13, נערך פעם אחת בסך הכל.
אני הייתי בוחר בגולף ובמיוחד בגלל הסיבות שהזכרת בהודעה. אני לא מהאנשים שמחפשים פוזה, אפקט הגעה ודברים כאלה ומעריך את פילוסופית ה״זאב בעור כבש״. נוסף לכך, לדעתי רכב כמו ה type r הוא מגנט ל״כחולים״ במיוחד משועממים ומתנדבים למינהם. GTI לעומת זאת אתה דיי ״נבלע״ בכל המכוניות הרגילות בכביש. בלי קשר, אם פרקטיות חשובה לך זה גם ייתרון נוסף. אם גם אתה מהאנשים הללו הייתי ממליץ ללכת על הגולף. בכל מקרה תעש נסיעת מבחן על שתי המכוניות.
בדגמים החדשים אתה מקבל כבר טורבו של חברה Borg Warner והוא נראה מאוד מרשים וגם נוסע ממש טוב
אבל בכל זאת עם הגולף הרבה יותר קל לעבוד, וגם מחיר החלקים לא כזה גבוה כמו בהונדה
אני אישית הייתי בוחר בגולף, עניין הביטוח המקיף זה גם בעיה רצינית למכוניות האלו, סביבות ה12000 ש"ח לשנה לנהג מעל גיל 30-27 וחברות רבות פשוט לא רוצות לבטח, הונדה זה בכלל סיפור, לפני הרכישה תתקשר תשאל אולי זה יהיה הרמז מה לקנות...
למה אתה לא הולך על גולף r?, בתג מחיר של ההונדה היא מתחרה ישירה לגולף r ולא gti. הגולף r הרבה יותר מתנהגת מהונדה, יותר חזקה, ויותר יפה לדעתי. בקשר ל gti הפרש מחיר של 85 אלף שקל מהונדה r. ברור ההונדה r תהיה יותר טובה מגולף gti.
ההפרש לא גדול כמו שאתה חושב 215 אלף לבסיס על הכביש בסביבות 224 אגרה ועוד כמה דברים קטנים ותוספת קסנון אתה נושק ל250.....ללא הקסנון והלד היא נראית הרבה פחות טוב כמובן לדעתי האישית
שאני יתחדש לי היה ממש קשה לי להחליט עד לרגע שעשיתי נסיעת מבחן לאחר מכן זה היה ממש ברור לי מה אני צריך לעשות לאחר שנים ארוכות עם וואגיות הגיע הזמן לרעות בשדות זרים בכל אופן שלום לכולם עד לוואגית הבאה
