[phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 483: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 483: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 483: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 483: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 483: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 483: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 483: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 483: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 483: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 483: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 483: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 483: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 483: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 483: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 483: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 483: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 483: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 483: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 483: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 483: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 483: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 483: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 483: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 483: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 483: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 483: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions_content.php on line 677: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 112: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions_content.php on line 677: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions.php on line 4764: Cannot modify header information - headers already sent by (output started at [ROOT]/includes/functions.php:3887) [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions.php on line 4766: Cannot modify header information - headers already sent by (output started at [ROOT]/includes/functions.php:3887) [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions.php on line 4767: Cannot modify header information - headers already sent by (output started at [ROOT]/includes/functions.php:3887) [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions.php on line 4768: Cannot modify header information - headers already sent by (output started at [ROOT]/includes/functions.php:3887) מתלבט אודי A3 1.8T | VAGIT
אוקיי מחר בבוקר קבעתי פגישה עם מישהו מרמת גן בקשר לאודי A3 1.8T אוטומטית
עכשיו אחרי בירור מכמה אנשים הרוב אומר שהאוטו לא אמין הגיר נהרס וכל שני וחמישי מוסך יש כמה ניצוצות שאומרים שאחלה אוטו שאם תחזקו אותו טוב הוא רק צריך תחזוקה שוטפת כמו כל יפנית ממוצעת. עכשיו מה את חושבים על הרכב מבחינת אמינות,אין לי בעיה לשלם קצת יותר בכל טיפול שוטף אבל חוץ מזה יש לי מחלות/תקלות ידועות?
תודה מראש
ואם אפשר לדעת מה המחירון שלה שנת 2002 140 אלף קילומטר יד שלשית
חד משמעית! מתלבט? אז אל תקנה את הרכב.רכב מומלץ לרכוש בלב שלם ובהרגשה מסופקת כאשר אתה בדיוק יודע מה אתה קונה. ואתה מתעניין ברכב וברכישתו כאן יום לפני שאתה הולך לראות אותו? ראשית,אם אתה די נעול כבר על מותג ודגם , אז תתעניין לפחות במחירון.(בתור התחלה)
יש לי כזאת אוטומטית . אני יכול להגיד לך בלב שלם שהרכב הזה מדהים נוסע טוב וחזק אם אתה שואל אותי? אל תהסס!! לגבי הגיר תבדוק אותו טוב לפני שאתה קונה בהצלחה!
אחרי שיחה קצת יותר רצינית עם הבחור לפני הבדיקה התברר שהאוטו לא יד שלישית הוא טוען שהוא טעה והרכב יד רביעית , כבר הפחיד אותי לא מוכן לרדת ממחירון ולא רק שלא מוכן רוצה 6 מעל למרות היותה יד רביעית 150 אלף קילומטר
היא מדהימה ביופיה ושווה כל שקל ואפילו מחירון אבל לא מוכן לתת 6 יותר
וקשה למצוא אחת נורמלית ביד שתיים אם יש לכם מישהו שרוצה למכור אשמח לשמוע
לרוב רכבי "ספורט" ימכרו מעל המחירון, אז אל תרגיש שעובדים עלייך ספציפית. אם יש על מה לבקש מעל, זכותו. לא ראיתי את הרכב, ובטח שאין לי מושג מה מצבו המכאני. אבל 6 מעל המחירון, זה לא ביג דיל בשביל רכב ספורט, עם שוק נמוך. מי זה לוי יצחק שיקבע מה מחיר הרכב על סמך השוק שלו. לגבי היד, כנ"ל, רכבי ספורט מחליפים הרבה מאוד ידיים, כל אחד מחזיק אותה שנתיים, לפעמים גם אונס אותך, ומעביר הלאה. הק"מ נשמע גבוה, אבל הוא סביר בהחלט לשנה שלה.
לכן אם אתה אוהב את הרכב קוסמטית (חיצוני\פנימי) ואם מצבה המכאני מעולה (אל תצפה ל100%), ויש לו קבלות על טיפולים בזמן, וחלקים חדשים (צמיגים\מצברים\טיימינגים ושות'), וכמובן מצב הגיר. אז לך עליה.
אבל תזכור שזאת ואגית מהשורות הראשונות, והאחזקה תעלה לך ביוקר (יחסית למזדה\יונדאי), ככה שזה לא יסתכם ב6 מעל המחירון.
