[phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 379: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions_content.php on line 677: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions_content.php on line 677: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions_content.php on line 677: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions_content.php on line 677: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions_content.php on line 677: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions_content.php on line 677: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions_content.php on line 677: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions_content.php on line 677: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions_content.php on line 677: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions_content.php on line 677: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions_content.php on line 677: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions_content.php on line 677: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions_content.php on line 677: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions_content.php on line 677: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions_content.php on line 677: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead בוקר טוב,מאתמול בערב הנעילה מרכזית החליטה שהיא עושה מה בא לה | VAGIT
בוקר טוב לכולם , אז כאמור הנעילה המכזית (מקורית) החליטה שהיא עושה מה בא לה הרכב הוא לאון 1800 TSi 2011 ידני ,אתמול בערב כאשר הגעתי הביתה ויצאתי מהאוטו תמיד הנעילה היתה פותחת את כל הדלתות אבל לא במקרה הזה , כאן היא פתחה לי רק את דלת הנהג וכאשר באתי לפתוח דלת אחורית מבחוץ זה לא נתן לי עד שלא לחצתי על פתיחת דלתות בתוך האוטו (הכפתור שליד הבלם יד) , אבל כאן זה לא נגמר גם היום בבוקר כאשר באתי לאוטו פתחתי אותו ובאתי לשים את התיק על המושב האחורי וגם כאן גיליתי שרק הדלת של הנהג נפתחה (בדקתי דלת דלת כולל תא מטען הכל היה סגור) , עוד לחיצה על השלט לפתיחת דלתות פתחה את כל הדלתות , ההגיון אומר לי שזה עניין של תכנות כי עד אתמול זה לא היה ככה וזה גם לא נראה לי כמו תקלה, נסיתי לשחזר מה עשיתי אתמול ונזכרתי שאחרי עבודה החלטתי לאוורר קצת את האוטו אז פתחתי את החלונות של האוטו עם השלט (לחיצה ארוכה על הכפתור פתיחת הדלתות) ויש מצב שהחזקתי יותר מידי זמן את הכפתור לחוץ , בספר רכב לא מצאתי על זה מידע אשמח לעזרה , בתודה מראש רמי .
אם יש לך לאון 2011 אז יש לך אופציה בלוח שעונים לעשות סגירה ופתיחה לפי הצורך שלך, דלת בודדת או כל הדלתות, תכנס לתפריט ותבחר שאתה רוצה שכל הדלתות יפתחו ביחד. יש שם עוד מלא אפשרויות...
תודה , בדקתי ואין לי בכלל אופציות לשינוי רק איפוס מונים וכדומה אומנם יש לי לאון 2011 אבל הלוח שעונים שונה מקופרה או FR המחשב דרך אצלי לא מורחב אז אין לי את האופצית שיש לך אני בטוח שזה עניין של הפעלת אופציה על ידי לחיצה לפרק זמן מסויים או קומבינציה של כמה כפתורים אחד אחרי השני או משהו בסגנון כמו עם אורות יום למשל ץ כולם בהתחלה מהירו להגיד לי שאיי אפשר לנתק שזה רק דרך וואג קום או דרך מחשב דרך מורחב אבל לא כך הדבר זה ניתן בקלות לשינוי עם משחק של סוויצ' ועוד כמה כפתורים ואפילו רשום בספר של הרכב איך לעשות את זה ... חבל שהספר לא איתי היתי מחפש בו שוב .
המ המ 150 קמש ? ב150 קמש מעניין אותך אם הדלתות נעולות חחח אני חושב שמישהו הוסיף 0 אחד יותר מידי את זה אני יודע איך לפתור אתה נכנס לאוטו מניע אותו וכאשר אתה בנסיעה של 20 קמש נניח , מחזיק את הכפתור שנועל דלתות ליד הבלם יד עד שהוא מתחיל להבהב כזה זה קרה לי אחרי שניתקתי מצבר בשביל התקנת מערכת וככה החזרתי את זה למצב הקודם וכאשר אגב תגיע הביתה או תעצור ותרצה לפתוח דלתות אל תדומם מנוע תעשה אותו דבר (לפני שפתחת דלת) רק הפעם תלחץ על כפתור לפתיחת דלתות ותחזיק אותו עד הבהובים , בהצלחה ...
נערך לאחרונה על ידי Ram_SL בתאריך 27 יולי 2011, 14:03, נערך פעם אחת בסך הכל.
בקשר לנעילה של הדלתות שרק דלת הנהג נפתחת זאת "נעילה סלקטיבית" אם הייתם פותחים את ספר הרכב הייתם מבינים שזאת לא תקלה... כדי לבטל אותה ולגרום לפתיחה של כל הדלתות יש לפתוח את דלת הנהג להכניס את המפתח לדלת (בזמן שהדלת פתוחה) ולסובב את המפתח ימינה לחכות כמה שניות, לשחרר ולבצע את הפעולה בשנית. בקשר לנעילה האוטומטית בזמן הגעה ל15 קמ"ש יש ללחוץ על הכפתור של השחרור דלתות לכמה שניות לשחרר וללחוץ שוב, כמובן שהאוטו לא בתנועה. זה אמור להחזיר את הנעילה האוטומטית
כל התשובות האלו כתובות בספר רכב אם יש לכם תקלה כזאת ברכב חדש בטוח תמצאו תשובה בספר חבל סתם לבזבז זמן בריצות למוסך....
לפעמיים בלחיצה כפולה על השלט (פתיחה/סגירה) אתה משנה את ההגדרות. נכון זה דפוק אבל מה נעשה יכול להיות שחבר שלך לחץ בטעות על השלט או על אחד הכפתורים של הנעילה המרכזית וההגדרות השתנו. ככול שהרכב "חכם" יותר ככה יש יותר בעיות..... שזה קרה לי בפעם הראשונה חשבתי שאני משתגע... שום דבר לא שינה את זה אז עליתי הביתה עם הספר רכב וקראתי בקפידה כל פרק שחשבתי שיכול לעזור לי... אני ממליץ גם לך לקרוא אותו, בנוסף יש שם דברים שאתה יכול ללמוד כמו ביטול אורות אוטומטים שנדלקים איך שאתה מדליק את האוטו ועוד כול מיני דברים.
האורות האוטומטיים, הם מהתוספות שאני לא הולך לבטל! ברכב הקודם הייתי נכנס, שם חגורה, מתניע, מדליק אורות (כל הזמן נוסע עם אורות דולקים לא משנה זמן, עונה...) ורק אז מתחיל לנסוע.
כאשר כתבתי את הנושא ספר רכב לא היה עליי , היתי בעבודה וקראתי את כולו כאשר קיבלתי את הרכב ולא זכרתי שיש בו משהו על זה , בכל מקרה תודה רבה לך אני הולך לנסות את זה תכף בקשר לאורות , לי נראה מיותר בשיא השמש עם חום 40 מעלות להמשיך לחמם את הפנס עם המנורת הלוגן ... ואגב אני בכלל ב6 שנים אחרונות לא ידעתי מה זה להדליק אורות (כמובן חוץ מתקופה שזה חובה גם ביום) או ווישרים כיבן שנהגתי על קסרה שעשת זאת לבד
*********עידכון********* זה עבד תודה רבה Leon_tsi עכשיו כל האוטו נפתח , נשאר רק דבר אחד קטן ומציק לא פחות , את האמת שגם בחוברת לא מצאתי או שכנראה לא הבנתי איפה מדברים בדיוק על זה , בעבר כאשר היתי מגיע לחנייה למשל ופותח אחת הדלתות זה היה פותח את כל האוטו כולל תא מטען ועכשיו זה לא פותח את כל האוטו אלה רק את אותה הדלת שפתחתי , הפכתי כבר את הספר רכב ולא מוצא יש שם לא מעט אופציות אבל אני לא מבין איזו מיהן פועלת ומונעת את פתיחת שאר הדלתות
