[phpBB Debug] PHP Warning: in file [ROOT]/includes/functions_content.php on line 677: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions_content.php on line 677: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions_content.php on line 677: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions_content.php on line 677: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions_content.php on line 677: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions_content.php on line 677: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions_content.php on line 677: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions_content.php on line 677: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions_content.php on line 677: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions_content.php on line 677: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions_content.php on line 677: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead שרשור הVCDS (או Vag-Com) הגדול (גרסאות, שאלות, הכל פה) | VAGIT
שלום חברים, רציתי לדעת איזה כבל וגרסה עליי לרכוש שמתאימים ללאון 2010 שיש לי, מצאתי כזה באיביי מה דעתכם? http://www.ebay.com/itm/VAG-12-12-0-Dia ... ls&vxp=mtr אם יש משהו יותר חדש או מחיר יותר טוב או לא יודע מה אשמח לקבל כל הצעה בנושא. תודה
קיבלתי את הכבל אבל כשאני מנסה להתחבר הוא אומר שהדרייבר של ה usb לא מעודכן.ואי אפשר לעדכן. מישהו יודע איך פותרים את זה? דרך אגב הגרסא 12.12.3 ואני עם ווינדוס 8(שוידאתי עם המוכר שהתוכנה תומכת ב8)
בסוף התברר שהתוכנה לא הייתה מתאימה.הכל הסתדר עכשיו. אם יש מישהו מאזור המרכז שמבין בתוכנה ויכול לעזור בבדיקה של ושינויים של כל מיני דברים אשמח להיפגש איתו. תודה!
אני ממליץ לכל אחד שכבר אין לו אחריות יצרן שיקנה וואג קום סיני (הוא דיי זול) ושיתחיל להתחבר לרכב ,לקרוא תקלות ,לקרוא נתוני מחשב ועם הזמן לחקור יותר ויותר ולעשות לוגים ותיכנותים. הכסף שתחסוך והידע שתיצבור בסוף יהיה שווה הכול.
