[phpBB Debug] PHP Warning: in file [ROOT]/includes/functions_content.php on line 677: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions_content.php on line 677: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions_content.php on line 677: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions_content.php on line 677: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions_content.php on line 677: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions_content.php on line 677: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions_content.php on line 677: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions_content.php on line 677: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions_content.php on line 677: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions_content.php on line 677: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions_content.php on line 677: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions_content.php on line 677: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions_content.php on line 677: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead תופעה מוזרה (גדישה לא יציבה) | VAGIT
ברור שיש בריחה, לא טענתי אחרת! אל תמהרו להחליף גם משאבת דלק לחינם כל עוד היא עושה את העבודה. קודם יש לסדר את כל הבריחות ולוודא שלא נשארה שום בריחה, ורק לאחר מכן לעשות לוגים ובדיקת ספיקה למשאבת דלק..
מסכים איתך ... רק ש"לוודא שלא נשארה שום בריחה" זה קצת בעיתי כי הוא יצטרך לשרוף 300שקל על בדיקת לחץ... אני מקווה שאת הבריחה יהיה אפשר לזהות בעין באור יום.
אין מה לעשות בשביל רכב תקין צריך כל הזמן תחזוקה. 300 ש"ח נשמע לי מעט גבוה אני עשיתי ב-200 ש"ח במוסך, היום אני עושה בחינם אגב בדיקת גדישה זה הדבר שהכי קל לעשות לבד בניתי לי קיט לבדיקה בבית.
* Mass Air Flow Sensors (G70) faulty * Intake Air System faulty/leaking (false Air) * Fuel Injector(s) faulty * Fuel Pump faulty * Exhaust System leaking * Secondary Air Injection System faulty/leaking
Possible Solutions
* Check Mass Air Flow Sensors (G70) * Check Intake Air System for Leaks * Check Fuel Injector(s) * Check Fuel Pump * Check Exhaust System for Leaks * Check Secondary Air Injection System
אנחנו עוד פעם חוזרים לאותה מסקנה... בגלל שהמאף חדש תשלול תאופציה הראשונה * Exhaust System leaking אמרתי לך שיש לך רעש של בריחות רצח מהצנרת .. תבדוק אותה ותתקן. אמרת שביטלת משאבת בוקר טוב .. תבדוק שהביטול נעשה כמו שצריך \ אולי צריך גם עדכון תוכנה בשביל זה. * Check Fuel Injector(s) * Check Fuel Pump וזה מה שאמרנו לך לגבי המשאבת דלק..
