[phpBB Debug] PHP Warning: in file [ROOT]/includes/functions_content.php on line 677: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions_content.php on line 677: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions_content.php on line 677: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions_content.php on line 677: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions_content.php on line 677: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions_content.php on line 677: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions_content.php on line 677: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions_content.php on line 677: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions_content.php on line 677: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions_content.php on line 677: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions_content.php on line 677: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead עזרה לגביי התחממות באיביזה FR 2005 | VAGIT
שלום לכולם ברשותי איביזה FR 2005 תופעה מוזרה ששמתי לב לאחרונה. התחברתי לאוטו עם תוכנת VAG-COM לראות כמה פרמטרים ושמתי לב במחוג ברכב הוא לא זז אבל במחשב רשום שהטמפרטורה 108 והגיע גם פעם אחת ל110. עכשיו עשיתי בדיקות קומפרסיה ולחץ הפוך והכול תקין אוטו סוחב מעולה אין מים בשמן ולא להפך ואין איבוד של מים. התופעה היא ככה אם אני מניע את האוטו שהוא קר ונוסע קצת הונטות נפתחות ב99 כמו שהם צריכות להיות לפעמים גם 101-102 זה סבבה. דרך אגב בנסיעה אגרסיבית של גדישות ומהירות גבוהה הטמפרטורה יורדת גם ל87 בVAG-COM מה שקורה לי אחריי לחיצות אני שם לב שהמים במיכל עיבוי עולים והוונטות לא נפתחות בכלל ולפעמים נפתח מהירות נמוכה ב107 ולפעמים בכלל לא אם אני נותן גז במקום אז הוונטות מתחילות להידלק. משאבת מים נבדקה נותנת זרימה חזקה יוניט רדיאטור הוחלף. האם זה יכול להיות תרמוסטט או רדיאטור? וגם אם אני נוסע עם האוטו הצינור התחתון של הרדיאטור מתחיל רק להתחמם בטמפרטורה של 96-7 לפי VAG-COM האם זה תקין?
אתה בעצמך שללת את נושא הרדיאטור כשרשמת שבטורים גבוהים הטמפרטורה יורדת.. זאת אומרת שמאפשרת שם זרימה, אז אינו סתום. גם בפורום השכן כתבו לך תקין.. אל תחפש הרפתקאות.!!
לא מחפש הרפתקאות ממש לא היה לי מלא רכבי ואג ואף רכב לא התנהג ככה וגם יש לי חבר עם רכב דומה שהוונטות נפתחות קבוע ב99 שאני עומד במקום זה מתחיל לתהחמם אבל שאני נותן גז זה בעצם מגביר את זרימת המים ככה שאם הרדיאטור סתום אז הטורים הגבוהים עוקפים את החסימה מאשר זרימה איטית כנ" לגביי תרמוסטט יש למישהו רעיון איך לבדוק שהכול תקין?
אם הרכב טופל כמו שצריך עם מים מקוריים הרדיאטור לא אמור להיות הבעיה. אני עדיין לא מצליח להבין איך אפשר לבדוק את המשאבת מים בלי להוציא אותה ולראות שהיא תקינה הדרך הכי קלה היא להתחיל מהטרמוסטט ולבדוק שהוא נפתח בזמן
