[phpBB Debug] PHP Warning: in file [ROOT]/includes/functions_content.php on line 677: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions_content.php on line 677: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions_content.php on line 677: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions_content.php on line 677: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions_content.php on line 677: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions_content.php on line 677: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions_content.php on line 677: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions_content.php on line 677: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions_content.php on line 677: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions_content.php on line 677: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead סקודה אוקטביה 2016 - 12V battery is low | VAGIT
האוטו חדש 500 קילומטר, איך כבר נגמרה הבטרייה? כמה זמן צריך בשביל להגיע למצב כזה? המערכת אומרת שאני צריך לנהוג ברכב כדי להטעין את הבטרייה. בגלל שהבטרייה כביכול גמורה, אני לא יכול להרים את חלונות החשמל כשהרכב כבוי, אין תאורה כשאני נכנס ויוצא מהרכב. אני לא נוהג הרבה, אז אני לא מצליח להטעין את הבטרייה. אילו פתרונות עומדים לרשותי? תודה
הייתי במוסך ואילו המסקנות: 1) המצבר תקין. 2) בגלל שאני לא נוסע כל יום, המצבר מתרוקן ויש כל מיני מערכות שגורמות לצריכת חשמל גבוהה כמו: וויז, בלוטוס, גיפיאס, איתוראן. 3) הומלץ לי להתניע את האוטו כל יומיים שלוש ל-10 דקות כדי להטעין את המצבר.
