[phpBB Debug] PHP Warning: in file [ROOT]/includes/functions_content.php on line 677: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions_content.php on line 677: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions_content.php on line 677: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions_content.php on line 677: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions_content.php on line 677: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions_content.php on line 677: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions_content.php on line 677: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions_content.php on line 677: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions_content.php on line 677: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions_content.php on line 677: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions_content.php on line 677: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions_content.php on line 677: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions_content.php on line 677: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions_content.php on line 677: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions_content.php on line 677: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead EPC נדלקת לסירוגין | VAGIT
מדובר ברכב סיאט איביזה 2002 20VT 1.8T נורת EPC נדלקת לסירוגין וזה לא קשור למתג אור בלם (הוא הוחלף) וכאשר היא נדלקת יש אור ברקס. מישהו יודע מה עוד זה יכול להיות?
כדי לבצע את הכיול למצערת: [Select] [01 - Engine] [Measuring Blocks - 08] Group 060 [Go!] [Switch to basic settings] Once you do this you will see the top right display say ADP RUN. The TB adaptation is being done as soon as you switch to basic settings. You will see the values change and hear the TB cycle for the first few seconds then it will stop. Leave it in Basic Settings for about 30 seconds. [Switch to Meas. Blocks] button and you're all set. Be sure not to touch the accelerator and make sure the engine is NOT running when you do this!
התוכנה שיש לי ה- VAG COM לא מלאה ולכן יש לי רק עד GROUP-25
הכיול לא עזר , נורת ה- EPC עדיין דולקת, בדקתי את המנורות ברקס, ואחת הוחלפה כי היא הייתה בשלבי סיום חייה, התקלה ממשיכה להופיע גם לאחר איפוסה לכן אני מחפש את הגורם הבא לתקלה. התקלות שמופיעות לי הן: 18048 - internal contr module (EEPROM) ERROR P1640-35-10---INTERMITTENT
17956 - boost pressure regulation valve (N75): OPEN circuit P1548-35-00
16955- BRAKE SWITCH (F) :IMPLAUSIBLE SIGNAL P0571-35-10--INTEMITTENT
אשמח לעזרה ובכלל אם יש למישהו רעיון מה לבדוק ומה הם הגורמים האפשריים לתקלה, או מניסיון אישי תקלות שיכולות להפעיל את נורת EPC תודה לעוזרים אלעד.
