[phpBB Debug] PHP Warning: in file [ROOT]/includes/functions_content.php on line 677: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions_content.php on line 677: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions_content.php on line 677: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions_content.php on line 677: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions_content.php on line 677: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions_content.php on line 677: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions_content.php on line 677: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions_content.php on line 677: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions_content.php on line 677: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions_content.php on line 677: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions_content.php on line 677: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions_content.php on line 677: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions_content.php on line 677: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions_content.php on line 677: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions_content.php on line 677: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead איזה אגזוז ממליצים לגולף | VAGIT
שלום ברושתי גולף V5 ידנית רציתי להרכיב לה אגזוז זרימה חופשית איז אגזוז ממליצים עליו במחיר סביר?? אני לא רוצה שיהיה מרעיש כמו טרקטורון אלא משהו יפה תודה
אם אתה קונה אגזוז ייעודי של רמוס לרכבך אז ממש לא ייחפור לך במוח, אם אתה במרכז אתה מוזמן לנסיעה איתי ולשמוע בעצמך.ללא ספק הדוד משמיע צליל מעודן שכיף לשמוע.
*** לקחת את רשמיי בערבון מוגבל *** *** הנעה קידמית עם הרבה הנאה ***
אני עובד מחוץ לעיר, ואחד הפחדים הכי גדולים שלי היו "רעש מציק", ואני יכול להגיד לך שקיבלתי סאונד איכותי, גם היום עם הדאון פייפ הדוד מספק סאונד מה שנקרא, חבל"ז חחח
באחד הרכבים הקודמים שלי היה לי סברינג ואני דיי הייתי מרוצה ממנו (אבל הייתי בן 18 וחיפשתי רעש אז לך תבין ) אני זוכר שבנסיעה מנהלית דיי שמעו אותו אבל הוא היה רחוק מלחפור ...
