[phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 483: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 483: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 483: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 483: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 483: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 483: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 483: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 483: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 483: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 483: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 483: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 483: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 483: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 483: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 483: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 483: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 483: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 483: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 483: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 483: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 483: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 483: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 483: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 483: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 483: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 483: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions_content.php on line 677: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 112: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions.php on line 4764: Cannot modify header information - headers already sent by (output started at [ROOT]/includes/functions.php:3887) [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions.php on line 4766: Cannot modify header information - headers already sent by (output started at [ROOT]/includes/functions.php:3887) [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions.php on line 4767: Cannot modify header information - headers already sent by (output started at [ROOT]/includes/functions.php:3887) [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions.php on line 4768: Cannot modify header information - headers already sent by (output started at [ROOT]/includes/functions.php:3887) החלטה אחרונה. | VAGIT
אז זה ככה לסיום..... מי שיש לו k04-023 שידבר איתי מי שיש לו gt rs במחיר של 10000 עד 11000 גם שידבר איתי כי הולך לשים אחד מהם את הראשון שאמצא במחיר סביר אני אשים
אתה רוצה ללכת עם הראש בקיר ביי מי גאסט אני חפרתי את הנושא הזה קצת יותר ממך אם אתה מטלבת בין k04 ל28 אל תחשבו פעמים 28 זמין כבר ב3 וחצי עם a\r נכון אתה מסודר בנוסף שהוא נושם הרבה יותר טוב בסלד גבוהה אבל עם אתה מתעקש על k04 תלך על ההיבריד הוא הרבה יותר חזק קצת פחות זמין ממש לא משו שתרגיש ויש לך גם שקט נפשי כי הוא עדין לא שבר כ"כ הרבה מנועים כמו k04 אני נוסע על הייבריד (לא מה שמוכרים בארץ קצת יותר קטן) ואני מאוד מרוצה..
תגיד נתי איזה אוטו יש לך ? אני גם חפרתי על ההיברד ותאמין לי שאמרו לי לא תרגיש את ההבל המשמעותי. אני יש לי כבר k03 sport של קופרה עם כל הסט אז אם אני אשים את ההיברד איזה הבדל אני ארגיש ? מה שכן k04 יותר חזק מההיברד ואל תתדאג אמרו שכול טורבו זמין שובר טלטלים גם ההיברד. בגלל זה אם אני חושב לשים את הk04 אני שם טלטלים. אז תגיד לי עכשיו מה כדי לי לשים ההיברד או k04.?
יש לי K04 על הרכב, סיאט לאון 2005, יש לי זמינות כל הזמן, אני גודש באר שבע, אין לי שום בעיות. אם הייתי יכול לחזור אחורה הייתי לוקח מינימום GT28. הרכב שלך כמו הרכב שלי די כבד, אז חבל לבזבז כל כך הרבה כסף על 300 כ"ס
רני יש לי קיט של k04 יחסית בזול אני קונה לא משנה את הכסף. אז תגיד האם הוא מהנה הטורבו הזה? הוא עומד בגדישות גבוהות ככה כמו שאתה אומר באר שבע ? והאם אני מרגיש הבדל רציני בינו לבין k03 sport? תענה לי על השאלות האלה ואני אהיה חייב לך יותג מתודה
