[phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 483: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 483: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 483: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 483: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 483: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 483: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 483: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 483: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 483: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 483: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 483: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 483: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 483: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 483: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 483: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 483: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 483: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 483: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 483: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 483: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 483: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 483: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 483: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 483: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 483: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 483: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions_content.php on line 677: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions.php on line 4764: Cannot modify header information - headers already sent by (output started at [ROOT]/includes/functions.php:3887) [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions.php on line 4766: Cannot modify header information - headers already sent by (output started at [ROOT]/includes/functions.php:3887) [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions.php on line 4767: Cannot modify header information - headers already sent by (output started at [ROOT]/includes/functions.php:3887) [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions.php on line 4768: Cannot modify header information - headers already sent by (output started at [ROOT]/includes/functions.php:3887) עזרה עם בוקסת נעילת ג׳נטים שחוקה | VAGIT
אתמול במסגרת טיפול שעשיתי לרכב (עם חבר שמבצע לי את הטיפולים במקצועיות רבה) שכלל החלפה של הרפידות ברקס האחוריות, כשרצינו להחזיר את הגלגל האחרון בו בוצעה ההחלפה התברר שהבוקסה של הנעילה נשחקה ולא ניתן היה לסגור את הבורג עם הנעילה. בלית ברירה נסעתי עם 4 ברגים במקום 5 ואח״כ קפצתי לפנצריה וקניתי בורג רגיל נוסף. באותה הזדמנות שאלתי גם אם יש להם במקרה בוקסה תואמת לבורג שיש לי ולצערי אין להם.
הבוקסה היא של חברת McGard, הראש של הבורג נראה כך:
[img]McGard.jpg[/img]
יש לחברה הזו המון ואריציות של צורת הראש, הן אולי נראות דומות מאוד אבל כמובן שללא הבוקסה הספציפית לא ניתן לסגור ולפתוח את הברגים. יש לי בבית עוד שני קיטים של בוקסות וברגים כאלו שהם כמובן לא באותה צורה ולכן זה לא יעזור לי.
הבעיה שאין לי את הקוד הספציפי של הבוקסה שיש לי כדי להזמין מהחברה, אני זוכר שצילמתי אותו (לפני 6 שנים...) ובלעדיו כמובן שאני לא יכול להזמין אחד זהה. על הבוקסה או על בורג הנעילה אין שום קוד.
כרגע אני במצב לא טוב, אם יהיה לי פנצ׳ר אני לא יוכל לפרק את הגלגל!
מה שאני מבקש לדעת אם למישהו מכם יש המלצה על פתרון יצירתי. האם יש משהו כמו בוקסה שיודעת להתאים את עצמה לצורה הספציפית הזו? זכור לי שראיתי בזמנו בפייסבוק איזה סרטון על כלי כזה שמתחבר למברגה ושמתאים את עצמו אוטומטית לכל צורה של בורג רק שאני לא יודע מהיכן להזמיםן כזה ואם הוא יהיה מספיק חזק כדי לפתוח בורג של גלגל ברכב שסגור די חזק.
הבנתי שמה שנהוג לעשות במקרה זה הוא לרתך אום רגיל לברגים ואז לפתוח אותם בצורה זו, אני אשמח לדעת אם מישהו עשה משהו כזה ברכב שלו, כמה זה אמור לעלות לי ובעיקר האם יש מקום שמומלץ לגשת אליו ולעשות את זה ושיעשו עבודה מקצועית בלי לשחוט אותי במחיר. אני מאזור המרכז.
כאמור כרגע המצב הוא שיש לי ברכב 3 ברגי נעילה שאין לי את הבוקסה לפתוח אותם וזו בהחלט בעיה רצינית שלא נותנת לי הרגשה טובה.
