[phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 483: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 483: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 483: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 483: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 483: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 483: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 483: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 483: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 483: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 483: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 483: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 483: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 483: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 483: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 483: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 483: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 483: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 483: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 483: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 483: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 483: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 483: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 483: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 483: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 483: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 483: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions_content.php on line 677: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions.php on line 4764: Cannot modify header information - headers already sent by (output started at [ROOT]/includes/functions.php:3887) [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions.php on line 4766: Cannot modify header information - headers already sent by (output started at [ROOT]/includes/functions.php:3887) [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions.php on line 4767: Cannot modify header information - headers already sent by (output started at [ROOT]/includes/functions.php:3887) [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions.php on line 4768: Cannot modify header information - headers already sent by (output started at [ROOT]/includes/functions.php:3887) רוחב ג'אנט - האם חוקי? | VAGIT
זה סט של 15" אבל זוג 7x15 et15, וזוג 8x15 et20. עכשיו שאלה: האם חוקי במדינה שלנו לשים ג'נטים ברוחבים שונים? אני גם יכול להזמין סט של 4גנטים: 8x15 - אבל בכלל אפשר לשים רוחב כזה באוטו שלי מבחינה חוקית? אם אני מקבל אישור להגדלת צמיג ל195.50.15, יהיה רשום באישור בכלל משהו בנוגע לרוחב?
מבחינת ביצועים אני יודע שזה יפגע אבל עד כמה? (יש לי קויילוברים)
אני יודע שזה לא טוב לשים גלגלים רחבים עם מנוע חלש, בגלל זה אני מבקש ייעוץ מקצועי רק ממבינים בתחום , ולא תשובות עם "עד כמה שזה דיבילי מה שאתה רוצה".
שלום גבר, נתחיל מזה שבימים אלו קשה מאוד להשיג אישורים. במידה וכן היית ממצליץ לך ללכת על 4 ג'אנטים זהים מבחינה פיזית כי במקרה ואחד מהם קיבל מכה קטנה אפשר להחליף אותו עם השאר, במיוחד קדמי/אחורי. אין קשר לרוחב הג'נט, באישור שאתה מקבל הוא מידת צמיגים, תדאג שתהיה זהה ב 4 הג'נטים. אם הקוילאוברים שיש לך אין להם אפשרות לכוון קשיחות תהיה לך בעיה, אם תנמיך יותר מדי הג'נט ישפשף לך את הדופן הפנימי או הכנפונים. חוץ מזה שיש להשיג ג'אנט דומה בארץ במחיר סביר, למה להזמין מחול ולהסתבך עם המכס וכל הבלגן של האישורים?? בכל מקרה שהיה לך בהצלחה
מכיר רכב שעליו מורכבים BBS מקורי במידה שאתה רוצה,לא יודע מאיפה ישיג אותם אבל ראיתי אותם על הרכב הזה בכרמיאל,נראים טוב מאוד.(רכב הינו סיאט טולדו בצבע בורדו). הבחור מוכר את הרכב עכשיו,דבר איתו ואולי תצליח לרכוש אותם ממנו.כאן הפרטים:
רכישת ג'אנטים מאי ביי זה סיפור שמלווה בהרבה כאבי ראש. בהצלחה.
נערך לאחרונה על ידי BENITO בתאריך 29 נובמבר 2011, 22:40, נערך פעם אחת בסך הכל.
תודה חברים, סוף סוף קיבלתי תשובות לעניין. -BENITO אני מופתע שיש כזה דבר בארץ, חשבתי רק גולף מארק 1כסופה (בתמונות ממפגש אחרון) לובשת ב.ב.ס. מקורי בארץ.תודה רבה אחי על הקישור,מחר אני מרים עליו פלפון. -quick_line כן, אני יודע אחי יש דגמים דומים בארץ, אבל משהאני ראיתי זה lenso bsx & lenso eagle. זה בדיוק מה שאני מחפש אבל אני צריך שיהיה עמוק. עם אתה יודע עוד משהו אני יהיה מאוד מודה לך.
אם אתה מזמין LENSO BSX ברוחב 9 אינץ, מן הסתם יהיה הליף עמוק. למרות שברוחב 7.5 הג'נט נראה הרבה יותר טוב, זה מה שהיה לי על הגולף שלי. יש עוד מלא אופציות חוץ מהכוורת.
אחי אני מאוד ישמח עם אני תועה אבל לפי מה שידוע לי אין lenso bsx 8/9x15. רק 7.5x15. 9 ו8 באים רק ב16", ואותם אני לא יוכל לשים.
ב bsx 7.5x15 גודל הליפ הוא 1.5", וללוק שלי אני צריך לא פחות מ-2" - זה כבר עמוק. גם לי לא כל כך בכייף לחפש בחו"ל ז"נטים. אבל עם הטעם שלי ועם השוק הג"נטים הישראלי אין בררה.
בכל מקרה מאוד ישמח עם משהו ימליץ לי על משהו בסגנון BBS RS בארץ. תודה.
