[phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 483: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 483: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 483: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 483: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 483: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 483: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 483: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 483: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 483: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 483: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 483: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 483: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 483: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 483: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 483: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 483: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 483: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 483: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 483: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 483: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 483: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 483: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 483: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 483: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 483: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 483: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions.php on line 4764: Cannot modify header information - headers already sent by (output started at [ROOT]/includes/functions.php:3887) [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions.php on line 4766: Cannot modify header information - headers already sent by (output started at [ROOT]/includes/functions.php:3887) [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions.php on line 4767: Cannot modify header information - headers already sent by (output started at [ROOT]/includes/functions.php:3887) [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions.php on line 4768: Cannot modify header information - headers already sent by (output started at [ROOT]/includes/functions.php:3887) בעיה עם קוילוורים של JOM ל-mk2 | VAGIT
שלום לכולם. לפני כמה ימים רציתי להוריד את "התחת" שלי, וזה משקרה:
הרמתי את האוטו עם ז"ק (נגיד צד ימין אחורי), בהתחלה סיבבתי עם המפתח של קוילוורים, והיה די קשה. קיצר הורדתי בסביבות 40ממ ואז לסובב ניהיה עוד ועוד קל יותר, ובסוף אני כבר סיבבתי עם היד בקלות, ושמתי לב שקפיץ כבר מתחיל "לנדנד" וניהיה חופשי. אבל לדעתי לא כל כך הנמכתי, אבל האום כבר שיחרר את הקפיץ לגמרה.
איך בדיוק סובבת את האום העליונה? לבד? או שתפסת את הקפיץ והאום ביחד וסובבת? כשאני מוריד אני תופס אותם ביחד ומסובב. אם זה לא עובד, ניסית אולי להוריד את האוטו ממש באיטיות כדי שמשקלו יתן קומפרסיה על הקפיצים? מה עם הצד השני? עוד שאלה קטנה, אני מניח שאתה מדבר על הקפיץ הקטן נכון? helper spring? זה שהשתחרר?
זה קורה משני צדדים. אני לא תפסתי בכוונה קפיץ ואום, פשוט סובבתי את האום עם המפתח, ובהתחלה ,כשזה היה צמוד מאוד לקפיצ קפיצ כולו הסתובב יחד עם אום, כהגעתי למצב שאני מסובב בקלות עם היד האום כבר הסתובב לבד אפשר להגיד, ההרגה כאילו באמת הקפיץ משוחרר לגמרה מצד, כלומר אין אליו לחץ מצד התחתון, אז הוא התחיל "לזוז", אבל משה אמרתה לגבי הורדת הרכב, זה נשמע לי די הגיוני, אבל אתה בטוח שהקפיץ ישב במקום שלו נגיד בפעולה כזאת, עם הוא "זז"?
שמתי לב שאצלך הקפיץ הקטן לא מתחת כמו שאצלי, יש הבדל? השתחררו לי שני קפיצים יחד, כאילו לא היה אליהם לחץ משני הכיוונים, והרוחב של הקפיץ (כאשר האוטו מורם) היה כבר פחות מהרוחב בין חלק העליון של קוילוור לבין האום.
אז מה כדי להוריד בקטנה את האוטו, ובקטה ל"להוריד" את האום כדי להוריד את האוטו? אבל עדיין מפחיד לדעת שהקפיץ זז, אפילו בקטנה.
לפי דעתי זה הגיוני, כי כשהאוטו מורם הבולם זה שמחזיק את הגלגל כך שהקפיץ לא מחזיק כלום. אולי תנסה למשוך את הקפיץ, תשים אותו על התושבת (האום) ואז אתה מנמיך והכל יחזור להיות רגיל. לגבי הנמכת הרכב מהג'ק, תעשה את זה ממש לאט לאט לאט ותושיב את הקפיץ במקום הנכון שלו. אצלי הhelper מלמעלה כן. זה טיפה אחר.
