[phpBB Debug] PHP Warning: in file [ROOT]/includes/functions_content.php on line 677: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions_content.php on line 677: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions_content.php on line 677: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions_content.php on line 677: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions_content.php on line 677: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions_content.php on line 677: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions_content.php on line 677: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions_content.php on line 677: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions_content.php on line 677: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions_content.php on line 677: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead טמבון אחורי-בעיה | VAGIT
אהלן, כמו שאפשר לראות בתמונה הטמבונים ברכב שלי צבועים. לאחרונה התחיל לקרות משהו שמאוד מאוד מעצבן אותי. הברק של הטמבון הצבוע והצבע שלו הופך מלבן ולצהבהב כזה. לפני שאני שובר את הכלים וניגש למוסך שצבעתי האם לדעתכם פוליש יכול לתקן את המצב? תודה רבה מראש.
לדעתי פוליש לא יעזור, אתה יכול לבדוק בפינה קטנה בצד של הפגוש אם זה עוזר. יכול להיות שכשצבעו את הפגוש לא עשו לך שכבת לקה להגנה (נשמע לא סביר אבל בכל זאת)?
אם פוליש עוזר אז אדרבה. זה מזכיר לי את העכירות הצהובה הזאת שיש על הפנסים, שאגב גם אותה פוליש מוריד. יכול להיות שהפגוש נהיה "עכור" בגלל השמש? יכול להיות שווקס פעם ב3 שבועות על האיזור יטפל בבעיה (במידה ותחזור)
אני צבעתי בדיוק את אותם חלקים לפני הרבה יותר זמן (שנה וחצי) והאוטו שלי חונה בשמש ואין לי שום בעיות עם הצבע, נראה מקורי לגמרי. אצלך בתמונות רואים הפרשי צבע עוד מהתמונות הראשונות.
