[phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 379: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions_content.php on line 677: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions_content.php on line 677: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions_content.php on line 677: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions_content.php on line 677: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions_content.php on line 677: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions_content.php on line 677: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions_content.php on line 677: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions_content.php on line 677: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions_content.php on line 677: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions_content.php on line 677: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions_content.php on line 677: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions_content.php on line 677: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions_content.php on line 677: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions_content.php on line 677: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions_content.php on line 677: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead התקנת RCD510 בלאון FR 2012 - שאלות! | VAGIT
ברצוני להתקין RCD510 ברכב מסוג סיאט לאון FR 2012. ברכב מותקן רדיו דיסק מקורי עם בלוטוט ושליטה מההגה, נדמה לי שזה RNS310. בכ"א, שאלתי היא, האם יש כאן חבר'ה שהתקינו מערכת זהה בלאון? האם חיישני החנייה המקוריים מסתנכרנים אוטומטית אל מול ה RCD510 ומציגים בתצוגה גרפית ע"ג המסך? האם מודול הבלוטוט המקורי שמותקן אצלי מהחברה מתאים ויסתנכרן בלי בעיה מול ה RCD 510, או שאצטרך להתקין מודול בלוטוט מחדש כדי שיתאים לדגם זה? האם ניתן לשנות את תצוגת הפתיחה לתצוגה של סיאט במקום זו של פולקסווגן ?
למיטב ידיעתי המודולים זהים בין המערכות ולכן יעבדו גם עם ה510. החיישני חנייה לא בהכרח יציגו תצוגה גראפית שכן ישנם מספר מודולים של חיישני חנייה ורק הOPS מציגים זאת. לדעתי לא התקינו לך את הOPS ברכב. אבל יכול להיות שאני טועה.
בנוסף, למיטב ידיעתי ואחרי שחיפשתי בפורומים מחו״ל, לא ניתן לשנות את התמונה במסך הפתיחה.
הצדק עימכם! המכשיר הוא RCD310 ולא RNS310 כפי שכתבתי בטעות בהודעה הראשונה. הרכב מגיע עם חיישני רוורס מקוריים, ודיבורית בלוטו מובנית מקורית עם שליטה מההגה על המכשיר והדיבורית. למיטב הבנתי, RNS310 כמו שמגיע כעת בקופרה R מסתנכרן אוטומטית עם החיישנים והבלוטו בלאון FR, אך חשבתי על RCD510 כמו של הגולף GTI, האם מישהו ודע בוודאות את התשובות לשאלות הנ"ל ? אם זה לא מתממשק זה לא שווה, פשוט עלויות מטורפות לכל המתאמים למיניהם.
OK, אז אם אני מבין אותך נכון, לצורך הבהרה, אני רוכש RCD510, מתקין אותו במקום ה RCD3י החנייה מציגים אוטומטית תצוגה גרפית, הבלוטוט מסתנכרן לבד ללא מתאמים, והשליטה מההגה הן על המכשיר והן על הדיבורית עובדת כרגיל? סליחה על השאלה, אך מניין הבטחון שזה יעבוד? ניסיון אישי, עבודה בתחום ? תודה.
נ.ב מישהו יודע אם אפשר\הצליח בעצמו לשנות את מסך הפתיחה של ה RCD510 מזה של פולקסווגן לזה של סיאט ?
כן בהחלט , זאת כמובן בהנחה שהחיישנים שלך הם OPS מקוריים ,הבלוטות מקורי ומדובר במודול שהותקן בחברה או יוצר בVW ולא במוצר אפטרמרקט . כאשר אתה ברוורס זה מה שאתה רואה ?
לגבי השליטה מההגה זה ודאי לגמרי מכיוון שאתה מחליף מכשיר OEM במכשיר OEM אין אפילו צורך במתאם קאנבאס. אין לך צורך להתנצל על השאלה - לא עוסק בתחום - מדובר בניסיון של כמה שנים והתעסקות שכוללת פירוק הרכבה והחלפה של המכשירים הללו על כל הפונקציות שלהם אינספור פעמים.
לגבי שאלתך על מסך הפתיחה התשובה היא חד משמעית לא האפשרות קיימת רק במכשירי RNS510 שמבוססים על WINce זה לא המצב עם הRCD שהוא מכשיר פשוט יותר .
אם תרצה לוודא את כל זה טרם הרכישה אין לי בעיה להעיף מבט . שלח לי הודעה בפרטי .
יש לך חיווי כלשהו כשאתה נוסע ברברס ? או שרק צפצוף ? אם זה רק צפצוף רוב הסיכויים שאין לך OPS ולא תקבל בrcd תמונה . שוב אם בא לך תעלה תמונות, קשה מאד להבין מה מותקן אצלך על סמך הסברים
נערך לאחרונה על ידי Mrmk6 בתאריך 10 מאי 2012, 21:58, נערך פעם אחת בסך הכל.
