[phpBB Debug] PHP Warning: in file [ROOT]/includes/functions_content.php on line 677: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions_content.php on line 677: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions_content.php on line 677: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions_content.php on line 677: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions_content.php on line 677: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions_content.php on line 677: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions_content.php on line 677: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions_content.php on line 677: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions_content.php on line 677: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions_content.php on line 677: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions_content.php on line 677: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions_content.php on line 677: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions_content.php on line 677: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead התקנת RCD510 בלאון FR 2012 - שאלות! | VAGIT
זה שונה בלאון, לא בדיוק מגירה, יותר פתח עם דלת שנפתחת כלפי מטה. אנסה להעביר תמונה עוד מעט. נראה שהכסא בגולף יושב גבוה יותר מאשר בלאון ואז יש מקום גם למודול וגם למגירה. בליאון זה או זה או זה. אני חושב שגם קראתי ברפרוף איפהשהוא בנט שלשני הכסאות יש מגירות למטה. צריך לבדוק את זה מול צ'מפיון.
היי, לגבי התמונה של המסך פתיחה אז אין לך מה לדאוג, ברגע שתרכיב את הRCD510 בלאון שלך אז אחרי ההצתה השניה של הרכב, המסך יתחלף אוטומטית ללוגו של סיאט. את המערכת RCD510 הישנה שלי מכרתי לבעל לאון 2010 וזה בדיוק מה שקרה כשהרכבנו את המערכת ברכב שלו(כשבמקור כשישבה בגולף שלי אז היתה עם הלוגו של VW)
אתם לא צוחקים עליי כן ? נשמע הזוי לחלוטין! ויחד עם זאת, אם אתה רציניים וזה מה שקרה אז כנראה שזה מה שאמור לקרות, מוזר ומעניין. מתנצל שלא העליתי תמונות אגב, מחוסר זמן, אפילו לא צילמתי עדיין אשתדל בקרוב.
מעניין! אפשר בבקשה לשאול באיזו לאון הותקן ה RCD510 הנ"ל? איזה שנתון\דגם, עם חיישנים מקוריים\בלוטוט ? אולי אותו בחור יוכל לענות מניסיונו גם על שאלת התאימות של הבלוטוט והחיישנים?
אגב, שמתי לב שב RCD310 אצלי, אומנם אין תצוגה גרפית של החיישנים, אבל ברגע שאתה מכניס ל R המערכת מורידה ווליום לבד, ממש כמו במקרה של צילצול טלפון בחיבור בלוטוט. האם זה אומר\רומז לכם משהו ?
שוב כדי לעשות סדר אין כל קשר בין החיישנים לבין לבין זה . ככל הנראה הסאונד של החיישנים שלך חובר למיוט של המערכת ובשניה שהוא מקבל פולס הוא מכניס את המערכת למיוט . כמו שאמרתי לך ככל הנראה אין לך OPS - אחרת היית מקבל חיווי מסכי גם ב310 . כמו שאמרתי לך נוכל לענות לך רק אם תעלה תמונות , אתה שואל שאלות שבלי לראות קשה לענות עליהן.
אין שום הגיון או צידוק להתקין בארץ rns510 הניווט לא יעבוד בו כי לא קיימת תמיכת מפות בישראל ובשביל האופציות של DVD ו הארדיסק פנימי שיש בו , הייתי הולך כבר על Hu אפטרמרקט טובה . לגבי הרפליקה הסינית במחיר שהיא מוצעת שוב יש לא מעט מכשירי אפטרמרקט מבית טוב שייתנו תמורה לא רעה , בטוח יותר מזאת של המכשירים הסיניים הללו .
