[phpBB Debug] PHP Warning: in file [ROOT]/includes/functions_content.php on line 677: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions_content.php on line 677: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions_content.php on line 677: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions_content.php on line 677: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions_content.php on line 677: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions_content.php on line 677: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions_content.php on line 677: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions_content.php on line 677: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions_content.php on line 677: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions_content.php on line 677: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead צריך עזרתכם בהתלבטות - 6X9 מורל אינפיניטי או רוקפורד?! | VAGIT
שלום חברים, היום יושבים לי ברכב: דאבלדין BLAUPUNKT NY-800 2רמקולים קדמיים מקוריים BLAUPUNKT (שומעים טוב מפתיע, האחוריים נותקו האיכות שלהם הרבה פחות טובה) זוג HERTZ 6X9 DCX690 במגש מגבר BOSS 1000w C650 (4x100rms) סאב INFINITY REF1260W סט חיווט ROCKFORD *את הציוד קיבלתי מחבר שמכר את רכבו בכמה מאות בודדות.
אני לא הכי מרוצה מהסאונד של הHERTZ כרגע הוא נשמע לי לא הכי נקי ולא מנצלים אפילו חצי מהכח שהמגבר מוציא, אני שומע בעיקר HOUSE או HIPHOP עמוסי באס והסאב עושה את העבודה כמו שצריך. המתקין שאליו אני כאמור לא אחזור, המליץ לי על INFINITY KAPPA 6X9 אבל אין לי את ה1400שקלים שהוא דרש להשקיע.
האם יש רמקולים בטווח המחירים של +- 500שקלים שיתנו תמורה מספיק טובה למחיר ויעשו את העבודה כמו שצריך? (לא פוסל גם יד שניה אם מישהו מוכר או ראה) כרגע מתלבט בין הדגמים: Tempo 6x9 Morel (בעיקר ממליצים עליו..) REF9633I Infinity T1693C Rockford מחפש סאונד כמה שיותר נקי אבל עוצמתי
המורל הם אכן הטובים מבין השלושה, תתחדש ! למעשה, ה 6X9 של מורל מדגם טמפו נחשב לאחד ה 6X9 עם התמורה הגבוהה ביותר לכסף, גם בעולם וגם בארץ. טובים ממנו יהיו דגמים גבוהים של בוסטון, הרץ היי אנרג'י ואולי עוד כמה.
