[phpBB Debug] PHP Warning: in file [ROOT]/includes/functions_content.php on line 677: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions_content.php on line 677: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions_content.php on line 677: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions_content.php on line 677: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions_content.php on line 677: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions_content.php on line 677: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions_content.php on line 677: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions_content.php on line 677: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions_content.php on line 677: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions_content.php on line 677: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead רעשי קיק מהסאב ללא מוזיקה | VAGIT
כשאני מתניע את הרכב והמערכת פועלת אך ללא מוזיקה הסאב נותן קיקים במרווחי זמן קבועים כאילו הוא לא מסונכרן עם המערכת.
לאחר שאני משמיע מוזיקה, אני צריך להעלות אותה לווליום גבוה יחסית כדי שהסאב יסתנכרן עם המערכת ויפסיק עם הקיקים ואז גם בווליום נמוך מאוד הסאב מסונכרן והכל טוב.
מישהו מכיר את התופעה הזאת ו/אן איך אפשר לבטל את זה?
הרכב עבר התקנה מאוד מקצועית ואני יוצא מהנחה שהכל מחובר כמו שצריך. הבעיה קיימת גם אם הכנסתי את המפתח בחצי סוויץ' והרדיו עובד. היא קיימת בעקרון בכל מצב שבו אני מזרים מתח באוטו. לפעמים הסאב מסתנכרן ישירות ועובד כמו שצריך ולפעמים הוא לא מזהה את אות הסאונד ונותן קיקים בתדירות קבועה עד שאני מגביר מספיק את הווליום ואז הוא מתלבש כמו שצריך על המנגינה ומפסיק את הקיקים העצמאיים.
לא נראה לי שזה רעשי דיסי מכיוון שזה לא רעשים אלא קיקים בביט קבוע. משהו כמו 80 bpm או פחות במרווחים קבועים.
