[phpBB Debug] PHP Warning: in file [ROOT]/includes/functions_content.php on line 677: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions_content.php on line 677: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions_content.php on line 677: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions_content.php on line 677: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions_content.php on line 677: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions_content.php on line 677: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions_content.php on line 677: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions_content.php on line 677: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions_content.php on line 677: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions_content.php on line 677: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead עצה לגבי סאב | VAGIT
שלום רב, היום אני משתמש בסאב של MTX 12" (למכירה דרך אגב) סאב מעולה! אבל הוא ממש גדול בבגאז' וכל פעם שאני נוסע לטיול או לכל מקום אחר אין לי מקום בבאגז', והוא נורא כבד להוציא אותו כל פעם.
נשמח לעזרה לעצה לסאב בגודל 8, כמה שיותר קטן וכמה שיותר איכותי. עד 2000 שח. מישהו מכיר? בזוקה אולי? מישהו מכיר מנסיון אישי?
שמעתי סאב 8" לא מזמן של sundow , היתי בשוק אני אוהב באסים מדויקים ולא אוהב חזקים מידי , לי יש גם סאב 12" אבל הוא עובד אצלי אולי על רבע עוצמה והיתי בשוק כאשר שמעתי בעבודה אצל חבר את הסאב שלו , הסאב פשוט קטן נותן בראש כמו שאני שומע בשלי 12" והכי חשוב הצליל לא בורח החוצה אתה באוטו יושב נהנה מהבאסים חזקים ומדויקים ומי שמחוץ לאוטו אפילו לא מנחשב שיש לך סאב בפנים הסאב עלה לו עם תיבה 950 שקל
אתה יכול להתרשם מהחברה באתר שלהם http://www.sundownaudio.com אני מנחש שמה ששמעתי זה היה ה200RMS מסדרה של E (אני לא יודע בוודעות) אבל אני מאוד אהבתי וכנראה בקרוב גם אחליף את שלי כי הוא פשוט ענק וגם ככה אני לא משתמש בעוצמה שלו, איך שיהיה קצת קאש בצד אני אחליף . אם אתה מהמרכז אני יכול להמליץ לך על מקום לקנות ממנו.
לי יש סאנדאון 10" מהסדרה הפשוטה שנקנה אצל יוסי. סאב מדהים. 1100 כולל תיבה. כמו שאמרו קודם - בקושי שומעים אותו מחוץ לרכב והוא מאוד קטן. לא בולט בתוך הבגאז' ותופס רוחב של כסא אחד. עובד מעולה עם מגבר מונו פאנצ' קטנטן של רוקפורד 300 וואט. פתרון מושלם למי שאין לו בגאז' גדול. (תאורה וגריל לא כלולים במחיר)
