[phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 379: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions_content.php on line 677: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions_content.php on line 677: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions_content.php on line 677: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions_content.php on line 677: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions_content.php on line 677: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions_content.php on line 677: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions_content.php on line 677: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions_content.php on line 677: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions_content.php on line 677: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead רעש בהנעה של מנוע 1.2 TSI 105HP | VAGIT
יש לי פולו 2013, עם מנוע TSI 1.2 יש איזה רעש מציק שמופיע בהנעות קרות כבר שנה +.
אני יודע שבזמנו היו בעיות עם השרשרת במנוע הזה, אבל ב2013 הם נפתרו. בכל מקרה, שמעתי איך הרעש של שרשרת תקולה נשמע (גם בסרטונים שמצאתי וגם אצל אוטו שהיה לחבר) וזה לא נשמע אותו דבר בכלל.
מישהו נתקל ברעש דומה לזה?
מופיע בסרטון בין 0:03-0:05. כשיש הנעה קרה יותר ארוכה, הרעש גם יכול להופיע 4-5 שניות ולא 2 שניות כמו בסרטון.
הרעש הזה מופיע כבר תקופה ארוכה - והרכב מטופל אצל רון. גם החלפת שמן לא עזרה.
השארתי אותו אצלו בלילה בזמנו והוא לא שמע את הרעש בהנעת בוקר. זה באמת לא תמיד מופיע, אבל בתקופה האחרונה (אולי בגלל הטמפ' הנמוכות יותר בחורף?) אני שומע את זה כל בוקר.
לפי התיאור שלך זה השמן. זה לא עושה שום נזק מיוחד למנוע, נטו פסיכולוגי. בכל מקרה, פעם הבא תנסה את השמן Liqui moly Leichtlauf באריזה סגולה. ליכטלאוף בגרמנית - "שקט".
עברו כבר כמה שנים והרעש עדיין קיים. ניסיתי להחליף לשמן שצויין פה... לא עזר. כשקר בחוץ זה מופיע בהנעה בבוקר ואחה"צ. כשיש ימים יותר חמים - זה מופיע לסירוגין.
האם זה באמת תקין? בפורומים בחו"ל כתבו לי שזה "Hydraulic tappets/lifters filling with oil"
אם זה באמת תקין... למה זה לא קרה ב2-3 שנים הראשונות עם הרכב?
נשמע כמו טיימינג,הייתה לי את אותה הבעיה עד שהחלק כשל ונשפך שמן מהמנוע. היה ריקול למנועי 1.2 105 כח סוס בחול על חלק "camshaft adjuster pully" עדיף תיגש למוסך כמה שיותר זריז שיבדקו את "camshaft adjuster pully".
לפי הסרטון והתיאור בכל השרשור אכן החלפת שמן לא תעזור לך. אין מצב שאצל רון שמו לך שמן לא מתאים למנוע. הבעיה כאן כנראה היא טיימינג (שרשת, מותחן, גלגלת פולי קאמשאפט), עדיף שתחזור על הביקור במוסך והשארה ללילה כי לאחר שנה זה כבר התחזק מאוד - מה גם שאפשר לבדוק זווית במחשב VCDS ולראות אם הטיימינג תקין. יכול להיות שיש בעיה מכנית אחרת במנוע אבל צריך בדיקה מקצועית.
