[phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 379: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions_content.php on line 677: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions_content.php on line 677: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions_content.php on line 677: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions_content.php on line 677: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions_content.php on line 677: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions_content.php on line 677: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions_content.php on line 677: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions_content.php on line 677: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions_content.php on line 677: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead משאבת דלק, מה נותנת? | VAGIT
מחזק את דברי אביתר לא תרגיש שום שיפור אלה אם תשדרג לטורבו גדול בשביל להחליט אם להחליף אז תבדוק את לחץ הדלק ברכב שלך אם הלחץ טוב אל תיגע אם לא תחליף למשופר יש לך של apr ושל וולברו מה עדיף זה שאלה אחרת
מצטער שאני מתעלק על השירשור, אבל אם כבר במשאבות דלק עסקינן...,לפעמים יש לי הרגשה שהרכב פשוט כבד ומרעיש יתר על המידה. אני אומר ומשווה זאת לפעמים שהרכב מרגיש קליל זורם ושקט יותר לאחר נסיעה בין עירונית של בערך 20 דקות הרכב מרגיש זורם יותר מאשר בנסיעה בתוך העיר כאשר ישנו מעבר שכיח יותר בין הילוכים 2,3,4. אין רעשים או צילצולים מיוחדים, רק התנהגות טיפה שונה של הרכב ושל דוושת הגז. חשבתי אולי משאבת הדלק עייפה... שירוקו 2.0 ליטר 2011.
מאור אצלך אין בעיה של לחץ דלק נמוך, במנוע שלך היא עובדת על לחץ של 150 באר ואפילו בסטייג' 3 אין מה לגעת. חוץ מזה שבמנוע שלך (ובTFSI) אין צורך לחבר שום שעון חיצוני, דרך הVAG-COM אפשר לראות הכל. כמה ק"מ הרכב עשה?
אז לא הבנתי למה הרבה יחסית שמשפרים מחליפים משאבה לאחת יותר חזקה? למשל ראיתי פה נושא של aviry שהחליף למשאבה של apr ב-s3 שלו. מה זה בעצם נותן? גם ראיתי שמלא עם רכב כמו שלי מחליפים לוולברו.
