[phpBB Debug] PHP Warning: in file [ROOT]/includes/functions_content.php on line 677: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions_content.php on line 677: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions_content.php on line 677: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions_content.php on line 677: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions_content.php on line 677: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions_content.php on line 677: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions_content.php on line 677: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions_content.php on line 677: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions_content.php on line 677: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions_content.php on line 677: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions_content.php on line 677: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead מרוץ הדראג בים המלח (28-29 במרץ) - השרשור הרשמי | VAGIT
שלום לכולם, אומנם VAGIT אינו (כרגע) מועדון אלא קהילה/פורום אינטרנטי בלבד, אבל כמו שרובכם יודעים, יש לנו כאן נציגות ממש לא קטנה של מתחרים בדראג. אני סבור ובטוח שאם היינו מועדון, היינו המועדון עם הנציגות הגדולה ביותר (כן כן, אולי הגיע הזמן באמת...).
פתחתי את התרד הזה מכמה סיבות: א. שיהיה מקום אחד שנוכל לדסקס על הדברים. ב. בדיוק בשביל זה יש פורום פורט מוטורי ואיזה כיף שהוא סוף סוף יתחיל להיות פעיל. ג. באופן אישי אני ממש מתרגש מהאירוע מחר, פשוט מתבאס שאני לא יכול להשתתף עדיין.
ואחרון חביב: אני חושב שמגיע למשתתפים וכל הסדנאות פה פרגון ענק על ההשקעה והמסירות. אני חושב שבלי זה, הספורט הזה לא יתקדם כמו שהוא מתקדם, ובאמת שמגיע לכולם פה פרגון אחד ענק!
אז יאלה, משתתפים, צוותי סיוע למינהם, צופים, ספרו לנו איך הולך בהכנות, ספרו איך האוירה במרוץ עצמו, תנו קצת תמונות ועדכונים מהשטח, מבטיח לספק גם בעצמי (קצת מהטריבונה וקצת ומהפיטס). הולך להיות חם!
לצערי, יש שני בעיות שלא הצלחנו לתקן. הראשונה זה הצמיגים, והשניה זה הלאנץ׳ שעדיין יש קירטועים ביציאה מהמקום. יורדים לעשות חיים, ולתת פוש לספורט שכולנו אוהבים!! בהצלחה לכל בעלי הואג שיורדים לתת בראש
הימים האחרונים עברו על חברנו BENITO ממש בלחץ מטורף , הדפרצניאל שהגיע היה לא של 2WD אלא של 4WD לכן לא ידענו עד אתמול האם ניתן להרכיב או לא, אתמול אחרי הרבה בדיקות הדפרנציאל הורכב יחד עם הקלאץ' החדש! והרכב כבר עומד במגרש החנייה בשדה תעופה בים המלח!!! לכל החברה דש ונפגש מחר!!!
בכוונה אני מפרסם כאן כי אני מאמין שנכנסים לכאן הרבה במהלך היום מחפש מישהו שנוסע מחר לים המלח ואפשרי להצטרף אליו. יש לי בקופות כרטיסים לשני הימים אך בדקה התשעים לפנות בוקר,לא יכולתי ליסוע. אשמח אם יש מישהו שנוסע ואני יוכל להצטרף אליו. תודה.
