[phpBB Debug] PHP Warning: in file [ROOT]/includes/functions_content.php on line 677: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions_content.php on line 677: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions_content.php on line 677: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions_content.php on line 677: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions_content.php on line 677: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions_content.php on line 677: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions_content.php on line 677: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions_content.php on line 677: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions_content.php on line 677: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions_content.php on line 677: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions_content.php on line 677: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions_content.php on line 677: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions_content.php on line 677: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions_content.php on line 677: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions_content.php on line 677: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead מה עשיתי היום ב-Vagit שלי (שרשור בעקבות ״פרוייקטים״ משונים) | VAGIT
אומנם לא ממש קשור למה עשיתי ברכב אבל קשור לעבודות שאני יעשה בהמשך.
ואחרי מחשבות רבות החלטתי ללכת על זה והזמנתי רתכת ארגון. בשלב הראשוני החלטתי ללכת על נירוסטה בלבד ( אלומיניום מייקר את הרתכת פי כמה וגם ככה בתור התחלה לא ייצא לי לעבוד באלומיניום)
רתכת תגיע רק שבוע הבא לא התאפקתי וקניתי כבר את הבלון ארגון
זה לא צנרת מקורית אלא משודרגת 2.5״ דאונפייפ של apr שנקרע לי הגמיש אז חתכתי בשביל להחליף ובחלק השני עד הדוד האחורי חתכתי בשביל להוסיף דוד מעבר כי אני רוצה שקט ( הצנרת הולכת להיות בלי ממיר)
סיימתי עם הצנרת מהדאונפייפ עד הדוד האחורי והרכבתי כבר על הרכב. בדאונפייפ עצמו היה טיפה יותר קשה כי צריך לבדוק באיזה זוית ומעלות הוא יושב בייחס לטורבו ..
אז סיימתי עם הריתוכים ומחכה למחר להרכיב את הדאונפייפ ולצאת לסיבוב
