[phpBB Debug] PHP Warning: in file [ROOT]/includes/functions_content.php on line 677: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions_content.php on line 677: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions_content.php on line 677: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions_content.php on line 677: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions_content.php on line 677: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions_content.php on line 677: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions_content.php on line 677: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions_content.php on line 677: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions_content.php on line 677: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions_content.php on line 677: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead מפגשון דרום- ים! | VAGIT
בשבת הקרובה נפגשים באשדוד כולם מוזמנים להגיע, גם הדרומיים וגם הצפונים! שעת מפגש 12:00 בצהריים (כדי שכול הפועלים יוכלו לישון טוב). כול אחד שידאג להביא שתיה קרה ומשהו לנשנש. לגבי החוף יש שלושה אופציות: הקשתות, יא, טו כול השאר לא באים בחשבון בגלל שדורשים כניסה דרך כורכר ויש כמוני שלא ביכולתם להכנס, אני אתן לדרומיים שמכירים את החופים להחליט על חוף עד יום חמישי. בינתיים כול מי שמגיע שיאשר הגעתו. לשאלות לגבי הגעה או מי שלא נרדם: 0546615205, תרגישו חופשיים להתקשר בין השעות 05:00 בבוקר ל23:00 בלילה. המשך שבוע תענוג!
אם הם לא מדליקים אש בשבת אז הם גם לא נוסעים בשבת לא? על האש זה יותר לוגיסטיקה, אם מישהו מוכן לקחת על עצמו את הארגון אז בכיף. למרות שגם עם כמה חטיפים אפשר להיסתדר.
אני אישית לא מדליק אש וכן נוסע בשבת, אני יודע שזה מוזר אבל זה מסורת שגדלתי עליה. אין לי בעיה לקחת על עצמי ערב של על האש אבל לא בשבת. למרות שעד עכשיו נראה לי שרק אני אתה ומקס מגיעים חח
אח שלי עכשיו הגענו לקיץ, עד עכשיו היינו בחורף, רוב החברים כאן יש להם חברות אז כול החורף הם ישבו בסלון ולעסו פיצות ששליח רטוב על קטנוע 20 סמ"ק הביא להם, ובניגוד אלינו שאנחנו חטובים הם יש להם משהו שקצת גורם להם לאי נעימות בהורדת חולצה, אז הם אומרים.. ים?! לא לא.. אין סיכוי.. אני יכנס לשרשור, יראה מה הם עושים ואפילו לא יגיב.. נראה לי נצתרך לארגן ערב על האש עבורם.. או אולי ערב סלטים? פריחיות אורז..? בכול מקרה אני מחר בע"ה נוסע לממדיון, אם מישהו רוצה להצטרף הוא מוזמן
